1 - 5 of 5 Posts
i am putting the puke tank for the trans in the rear of the car. what size line should i use to the tank? i imagine a -4 should be good but just want to be sure.
Thats fine but remember , if oil accumulates in the line it will alter the oil level readings so for accurate oil level checks always undo the vent hose from the trans to properly check the oil level.
Hutch
would a -6 line be better than the -4 and help with checking the fluid?? thanks for the very quick reply!! mike
got it! thank you very much. mike
1 - 5 of 5 Posts
