1 - 2 of 2 Posts
Made a test hit at our local hedsup race lastnight hit good at first but blew the tires off and tried to peddle it but nothing was there Did all the simple checks cable,fluid etc all was good it was a little low on fluid but did the same thig after it was filled properly.Going to pull it apart later in the week I figure its the band or band adjuster.Any toughts? Thanks in advance for your responses!
Sounds like you have smoked the band. To veryify , loosen the band adjuster nut and wind the adjuster bolt in counting the turns. I bet it will just keep going in. (4 turns is the spec) .
Pull the trans and have it fixed.
Hutch
1 - 2 of 2 Posts
