1 - 4 of 4 Posts
I bought a core to get the case to swap my parts into. It's an early model with the rear pump and coarse 16 spline output shaft. What do I need to do to convert this case to a std setup?
I also found an early model air cooled glide with the 4 big holes in the bell housing. Is this case OK for a performance application? What modifications are needed?
If you are just using the case , drill the passage for the transbrake feed as the old case will not have a "lower hole" and use the non rear pump governor support and gasket and you should be fine. Be sure to air test the reverse circuit when your done.
Hutch
1 - 4 of 4 Posts
