Which type of Band Material would you suggest for a racing PG, lost the low gear band which was red, looking at either red or kevler.
found a bad seal on the pump, locking type worn very thin so must have been losing PSI there which would drop the servo PSI, groove seems OK so I will install new teflon seals and install a new band and check the line PSI.
