anybody have an idea .just put the prick in .1.76 glide with pro brake
on third stop and down shift my
. fist gear bound up like it was on brake .
high gear is fine. no drag and holds speed. limped it home in 2nd
shifter linkage is dead on and tried it with it off . still binds
trans brake noid is not stuck and tried loosening it out .same bind.
my flow chart has manual shift valve supplying the band servo and rev. valve with psi in low could the rev. spool valve/valve body be leaking and applying psi to rev. piston ?
i have not even tried the brake or rev. yet..
