Can someone tell me what it involves in converting a standard diameter input shaft to one of the over size ones. This would be for a HI, HP application. Thanks
What you are using should be fine. If you want to upgrade , how far are you willing to go?Right now I'm not having any problems. 2500lb. tube chassis 706-2 systems. I am using Coan best stuff, ring-less input (standard Dia.). I'm planning on changing to a supercharged motor it should be 2200-2400 hp. Just thinking of upgrading my input shaft size to maybe head off any problems. I see all the major players in trans are offering a larger input (1 1/8---1 3/16 maybe more) on there best stuff. Thanks
