WE HAVE A 598 BBF W/PG TRANS the car will walk when you turn the starter and when it stsrts it will move forward about 3 inch if you rev the motor linkage can be removed and it still does it any help
Powerglides do not have an actual neutral. The resistance in the planetary and clutch/band drag will make the car lunge forward when it starts and when you rev the motor. Is this what you are feeling?
some,but what got me is it pulling forward when the engine is cranking it acts just like a old stick car when you go to start it and havn't pressed the clutch
