1 - 11 of 11 Posts
SBF TTFMF
For my next build I want a stockish build. So my question is, could a cam be ground that sounds like stock but performs great? Combo will be ported stock intake (302 mustang) with edelbrock perfromer heads and a custom cam. Also will have a 175-200 shot on it. Stick shift car..thanks.
What kind of cam were you thinking of useing, HFT or SFT or HR or SR? But yes you can make a sleeper cam fairly easy.
id be using my custom hyd. roller cam... 113 212- 516 intake / .480" - 200 degree exhaust... its a small spec that is insanity for low to mid power , idles very good , will pass smog in some combos. advertised duration at .006" is only 260/262 degrees.
SBF TTFMF
Idles very good as in damn-near stock? I don't want people thinking I have a killer...This would be good to 6500 rpms? Could I just go on your website and order this? Thanks
yeah 6500 with the right heads , stock 302 heads no way...
call me up for ordering that custom grind.. 951 296 9669
might spread it to 115 to quiet it more for ya.
SBF TTFMF
Discussion Starter #7
Yeah, I don't mind a little bump in my idle, I could just say I have 1.7 rockers...but the more stock sounding the better. Ill definitely give you a call..how much do your custom grinds run? I'm assuming in the 500-600$ range for a billet HR...
1 - 11 of 11 Posts
