1 - 1 of 1 Posts
Vendor
The PerformAIRE PRO is the latest in professional grade precision weather measurement and data collection in a self contained system. PerformAIRE PRO allows your Personal Computer to gather weather data and predict the performance of your race vehicle, that information is then transmitted to you anywhere at the track with built in Paging or "Smart Phone" texting capability. Paging will function without Personal Computer to transmit weather data only, no prediction info. Custom designed rainproof enclosure is easily mounted using standard "extension pole" style threaded mount. A single cable connection is all that is required to connect system to your Computer. Integrated paging system does not require a mounted antenna or antenna cable. Optional Remote Display allows system to display weather data without a Personal Computer.
PerformAIRE PRO includes RaceWORKS Electronic Logbook Software. RaceWORKS controls the entire system by taking weather readings from the PerformAIRE PRO, sending Paging information, and stores and uses run data to calculate predictions. This easy to use software allows you to create multiple logbooks for different vehicles and multiple events for each logbook!
Click here for more info->https://www.altronicsinc.com/racing-weather-stations/trailer-based-racing-weather-stations/performaire-pro-1.html
1 - 1 of 1 Posts
