1 - 5 of 5 Posts
Gas Passer
How are you guys setting up the chassis on the 275's...this is a SBNOS if it matters. Just wondering how to preload it to make the car go straight down track on two foggers. I have heard different things and would just like to hear how everyone's car is set up as far as preload. Thanks Bullet!!!
Gas Passer
I thought it was supposed to be neutral with one half turn more preload in passengers...so under load, they are basically neutral.
There's really not a given number that works for every car.. kinda depends on corner weights at static .. just set it neutral , go to the track and then adjust pre load till it goes straight...
The car needs to be at race weight with you in it. Have someone go under the car and set them to neutral. Start with that and adjust if needed.
1 - 5 of 5 Posts
