1 - 20 of 22 Posts
Hey guys just wondering how fast people have been with a paxton novi 2000? i am currently running one at 55000 rpm impeller speed on a 355 ci chevy running 8.80's in a 3256 lb nova on E-85. How hard have you guys turned these blowers? Im at sugested redline at 55000 and wondering what everybody elses experience was
That combo' is one of the faster results I've seen with the Novi 2000. I'm not sure what the potential of the newer Novi 2200 (JT-Trim Vortech) is but, congrats on your E.T.'s.
---==Temio Williams
Yuba City, CA
Your doing real well if your in the 8.80 range at that weight. 55k on the impellar is fine as there is some safety factor into the 55k limit that was built in. You could probably run up to 60k but you will be pushing your luck.
I spin about 53k and run 9.20s at 3280 on a 351w
Curious what are all details about the car? Shift points, tires, gears, tranny....ect
thanks for the input guys , heres details of my setup, stock gm block .030 over to make it 355 c.i. with program splayed billet caps and a half fill of hardblock, gm forged steel crank with Howards billet steel 6.125 rods and srp flat tops .010 in the hole, comes in right around 9.5 to 1 with a set of AFR 227's. The cam is a Crower solid roller Part #00427, its .624/ .636 with a 1.6 rocker and 260 266 @.050. Strip dominator intake with a quickfuel E-85 750. Im running a th350 with a 12 bolt with 4.10 gear and a 28 10.5 et drag, Usually like to shift the car at 7800 and it has the light on at the end of the track, not sure exactly how hard it turns out the back door but im figuring its around 8100 rpm
that is twisting it for sure. the numbers dont lie but i cant help thinking that it might be faster with less gear. that is flying .
nice car.
When greco ran pro 5.0, he always had 4 or 5 back up blowers in his trailer. He and Dave Zarlow did most of the testing for Paxton.
man 8.80's is fast on that charger
what kind of boost are you seeing and trap speed?
east coast super charging has gone 8.6s on one vette and 8.8s on another. one was a 402 and the other was a 346 running OEM 243 ls6 heads.
6 years ago or more
9.2's with a stock 302 with edelbrock RPM heads, hyd lifters, c4.
made 20lbs of boost max
NICE! is that with the old setup? i remeber you posting some pics of a motor with trickflow, 8" crank pulley, and some other stuff.
Yes, that was the first all out pass with the new motor. It's a stock cube LS2 (budget build) w/Trickflows, 10 rib 8"- 3" setup.
Tune is conservative for now (can't afford anything to go wrong)
Looking to go 8.5 this fall. Meanwhile I race 9.50 index with it.
What kind of rpm do you turn?
I usually shift around 6800-7000. Last year I was going through the traps at 7k. (7.5" balancer & 3.25 pulley)
This year shifting the same and I forgot to look at trap rpm.
(I also changed from 3:90's to 3:42's)
If you keep patting yourself on the back your gonna need one of these.
1 - 20 of 22 Posts
