Agitene - I use the 141 flash point, which is the only one legal here in Michigan. It's also suppose to be environmentally friendly with no hazardous ingredients. Which I don't fully comprehend as it is a petroleum solvent.
http://www.grainger.com/Grainger/GRAYMILLS-Parts-Washer-Cleaning-Solvent-2RE49?Pid=search
I get a kick out of this when company’s try and push the "environmentally safe" speech.
As soon as you use it it's now hazardous. lol
YepI get a kick out of this when company’s try and push the "environmentally safe" speech.
I do the same thing with the ATF ,Mineral Spirits with a touch of transmission fluid thrown in, helps my skin from drying out to much and does a great job dissolving carbon. I put in half a qt of ATF DexIII per 5 gallons.
I didn't like agitene. Seemed like it would eat through gloves.
aqous bio part washing systems are nice.
blow dry with a air gunWhat do you guys do with your parts after the solvent tank? Hot water rinse in a sink? Rinse with the hose? Blow dry?
Sam I spoke with safety kleen at pri you can lease them or buy them. I opted to buy a parts washer off ebay new but it is not the drum below type, it has solvent in lower part of the parts washer at all times with a shelf half way up in side you can remove. it will work fine for me.where's a good place to get one solvent cleaner 30gal. drum/upper tank deals at?
How do you get rid of the solvent when done with it?
Give it to someone with a waste oil heater. They usually love the stuff, along with your old oil, trans, etc.How do you get rid of the solvent when done with it?
