1 - 8 of 8 Posts
Kelly's Nightmare
Anyone have any pictures or can you tell me how to burp or keep the radiator air pocket free when it's layed parallel to the to the ground?
so i need to run a larger radiator if it'a mounted flat?
x2...might end up going this route also!
i actually put a filler neck up high. they make a rad u can buy with no filler neck. so u dont have to worry about it leaking.
Custom Engine Shop
Just make sure the front of car is up or on ramps.
And use a expansion type filler at the t-stat and burp from there.
Kelly's Nightmare
What about on a car with a "dry" intake manifold and no filler provision?
Custom Engine Shop
Where are you pumping from and to?
High side of the return from the rad is the place to burp from.
you can also use an air vac which some tool companies sell. it uses compressed air to pull a vacuum on the system and then you let it suck the antifreeze in. we use it all day long at our shop.
1 - 8 of 8 Posts
