Bullet .800 lift solid roller with 1.8 rocker ratio for Ls na motor. I was told to run at least 250/750 spring pressures and 275/800 was optimum. I found a lot of choices in retainers for either spring because I need .100 tall retainer to bring up the install height up.Can't go wrong with either set, but are they the correct ones for the app? Hard to say without more info......................
is that the pressure Bullet recommended? would like something in the 300lb seat range.Bullet .800 lift solid roller with 1.8 rocker ratio for Ls na motor. I was told to run at least 250/750 spring pressures and 275/800 was optimum. I found a lot of choices in retainers for either spring because I need .100 tall retainer to bring up the install height up.
what dia.?Bullet said I could run 350/900 Ibs. with these lobes. My install height should be between 1.96 to 1.97, so the PAC springs should be around 285 at that height. And I could set the Manley's at 1.95 and get at least 275.
the 1224 spring says its [email protected] im a dealer. in their book, they list their spring pressures at .050" increments.Bullet said I could run 350/900 Ibs. with these lobes. My install height should be between 1.96 to 1.97, so the PAC springs should be around 285 at that height. And I could set the Manley's at 1.95 and get at least 275.
1.625what dia.?
With a standard retainer I was at 1.91 on the intake and 1.925 on the exhaust. And 1.965 on the intake and 1.980 with a .100 tall retainer. These measurements were with 1.550 spring retainers and .060 locator.the 1224 spring says its [email protected] im a dealer. in their book, they list their spring pressures at .050" increments.
if you can get a true 2" installed height, I would run the #1228.
PSI has a spring might work
you can get some spring locators in .045" tooWith a standard retainer I was at 1.91 on the intake and 1.925 on the exhaust. And 1.965 on the intake and 1.980 with a .100 tall retainer. These measurements were with 1.550 spring retainers and .060 locator.
I've heard of PAC lasting longer and is a better quality spring. Personally don't have any experience with either so I really don't know.Which one's will last longer before changing them out?
Ive used quite a bit of the manleys...(polished) version with VERYWhich one's will last longer before changing them out?
Yes, i'm a PSI fan.WARP, any update on that RO7 415 cui motor you guys did???.....really want to know
OH and X2 on the psi springs,,,, one of the best out there also......
Just curious do you like PAC or PSI better. Or do you base it upon application like I have.Yes, i'm a PSI fan.
would be both, depending also if both had a similar spring for the same application. Really like the PSI stuff, and in ten yrs, i've only broke one spring.Just curious do you like PAC or PSI better. Or do you base it upon application like I have.
