1 - 12 of 12 Posts
who has the CM k member from them?
how much does it weigh in total using the factory motor mount pads?
Yes that will be with the stock cast iron stands.
For 93-97 f bodies?
98-02 f bodies?
thanks
Just call Jason and ask him
Nitrous Junky
I have it on the board at home. it was a 33Lbs savings with K and arms. I just put it back in last night after I cut the engine mounts off and put manual rack mounts on it. she was 4Lbs lighter ;)
Nitrous Junky
BTW Mounts were almost 8Lbs and they are gone now to ;)
Like others said, call him. He is a great guy to deal with and makes some nice stuff.
Moly k-member weighs about 14-15lbs with no mounts if you want the stock plates so you can use your cast Iron stands and motor mounts add another 12. We do a light weight version with the bottom mount built in (clamshell type) and offer a solid LS1 Alum motor mount (weight is 2-3lbs). PM me for more info.
1 - 12 of 12 Posts
