1 - 5 of 5 Posts
Anyone have a billet or nice alum filter to VB spacer for a PG with deep pan?
Would like to see a picture please of spacer/correct filter.. The one i have is crap and does not seal to filter. Looking to make one if there all made the same as the one i have.
Thanks!
I have a few. Ones that take PG filters in the stock location , ones that use PG filters in the rearward location and ones that use chrysler filters. Which one would you need?
Hutch
Anyway to see these?
My PG does have a 727 style filter on it.. The spacer is cast alum and made like an H-beam it seals on the VB with a gasket but on the filter side can't seal because of the low place in brass filter and the H-beam style spacer. If the spacer was 100% flat on filter side it would seal and all oil would be filtered.
I will try to post a picture to better show whats going on.
Thanks!
I got it fixed up.. TCI had a billet spacer that work perfect!
Thanks!
1 - 5 of 5 Posts
