1 - 11 of 11 Posts
My car is coming back together after extensive downtime. I decided to be a bit different and put a cog drive F1C on the ol Cobra. Car sports a new valvetrain, front mount A-A, TH400 trans, and spooled 8.8" with 3.73's and 28" tire. For the life of me, I can't seem to narrow down the perfect cog pulley setup/ratio. I'm hoping to trap close to 150 which puts me at 7100 RPM assuming 6% slip thru the 400. I need to determine where in the powerband I should hit the blower redline of 74K RPM, and how much can the F1C be over-spun? I'd like to make 27-29 PSI and max out this blower.
I got the 70T crank and 38T blower initially, which is only 70626 RPM at 7100 @ 150, thats probably not gonna work, blower wouldnt hit redline until 158 MPH and I dont think the car is gonna go that fast.....
800 RWHP should be almost enough powa to run an 8 at my weight if the converter is correct
Any ideas or starting points?
I wouldnt overspin a 74K blower but thats just me.
I run a 7.25/4" pulley and go through the lights at 153mph around 7220rpm which puts the blower around 71K. I have run a 3.9, 3.8, and 3.7 pulley and while the boost does go up so does the heat and the car really doesnt pick up a whole bunch going smaller than a 4 inch. I might do better with an A2W IC but the A2A I have is marginal at best with this blower.
Thats an F1A though which is smaller than the F1C, same 74K max impeller though. I would try what you have and see what happens rather then try to max it out right off the bat, you may be surprised what it does..
Discussion Starter · #4 ·
What kinda boost does your combo make with the F1A?
I've looked on several sites to find out how to calculate blower speed. Can't quite get it. I'd like a lesson please. School is in. I'm running an F-2.
Thanks Brian, just what I was looking for. I love this site.
Around 18psi @ 7200rpm when it ran the 8.90s with the 347 with a 7.25/4 pulley, naturally more CID = less boost on the gauge.
I was going to try a F1C but I dont think my 8 rib drive will handle it, neither will my 170.00 eBay intercooler ;)
crank pulley dia (or # of teeth) X blower step up ratio X engine RPM
Blower pulley dia ( or # of teeth)
Discussion Starter · #10 ·
Thanks for all the great info. So going 152 at 7200 sounds like you run a 28" tire and 3.73's?
I'd like to keep the 3.73's so I have some room to grow ET wise, but I dont want it to be a slug outta the hole. I'm hoping Lenny's new converter (UCC) will be close. Its basically the same converter as Bart Toebner, NMRA Renegade, and should stall at 5600-5800, so I hope to make some decent boost on the T-brake.
Yea, 3.70 with 10.5x28S tires.
I have an ATI 8" 5500 converter in the car and I'm very happy with it. I leave at 3000 on the 2 step, thats only about 3-4psi but any more than that and I get into wheelstand issues. Most likely with less CID you wont have that problem. But 1.25-1.28 60's at 3000rpm on the two step is fine with me, easy on parts if anything.
1 - 11 of 11 Posts
