1 - 5 of 5 Posts
Currently have wheel studs that are m12x1.5 with a 14.2mm knurl. Couple of them stripped out and by time we got the holes round again the holes in the hub are 15.5mm.
Are there any m12x1.5 with this size knurl? Tried looking at arp and with a knurl that size it's all m14x1.5.
New and used hubs are too expensive right now. May consider threading the hub if there's a threaded stud that would work. M18 thread on one side with m12x1.5 for the nut.
So I'm looking for a m12x1.5 with 15.5mm knurl.
Also tried napa, car quest, oreilly, autozone with no luck.
Any help is appreciated.
Have you gone online and looked at the Dorman catalog featuring hardware and fasteners? They have the lug studs separated by inch or mm. Just a suggestion - good luck in your quest!
Did a quick search on Summit... Dorman shows 12mm x 1.5 studs with 15.55mm, 15.80mm, and 16.1mm knurls. Currie has a .610” knurl which is 15.5mm. If you’re willing to switch to a 1/2” lug nut you’d also have a bunch more options. I have upgraded quite a few cars from 12mm to 1/2” studs and had no problem fitting the 1/2” acorn nuts on factory wheels. Should be able to find some of those Dorman part #s local or on Amazon if you’re in a rush.
1 - 5 of 5 Posts
