1 - 8 of 8 Posts
Administrator
Below are the rules for Outlaw Big Tire. It's an 1/8 mile class.
Outlaw Big Tire Y.B.Nationals only
1. .400 Pro Tree heads up racing, using a pro ladder.
2. All NHRA & track safety rules in effect.
3. All cars must retain stock appearance, profiles and dimensions. Factory roof & quarters must be used. Lexan windows permitted.
Aftermarket light weight body parts limited to: hood, doors, fenders, decklids,and bumpers. Aftermarket spoilers/wings permitted.
4. Any type chassis and suspension permitted. Wheelie bars permitted.
5. Mufflers or inserts required on all vehicles except turbocharged vehicles.
6. Functioning headlights, taillights and brake lights mandatory.
7. Any size tire allowed. Slicks permitted.
8. Any transmission permitted (limited to five forward gears)
9. Stock wheelbase mandatory. Maximum wheelbase stagger 1".
10. Lower engine containment device(diaper) mandatory.
11. Intercoolers permitted with use of gasoline, prohibited with use of alcohol.
12. Weights will be as follows:
Naturally aspirated under 600ci-2400lbs, 600ci-710ci-2500lbs, over 710ci-2600lbs.
Small block nitrous 2600lbs
Small block centrifugal supercharger 2800lbs
Small block roots supercharger (max. 14-71) 3000lbs (screw type, billet and M-5 superchargers prohibited)
Small block single turbo (106mm max) 3000lbs
Small block single turbo bigger than 106mm 3100lbs
Small block twin turbo maximum 88mm 3100lbs
Big block nitrous 4.84 bore space 2800lbs,(deduct 50 lbs under 670 CID), 5.00 bore space 3000lbs, 5.2/5.3 bore space 3300lbs
Big block centrifugal supercharger 3000lbs
Big block roots supercharger(max. 14-71) 3300lbs (screw type, billet and M-5 superchargers prohibited)
Big block single turbo (106mm max) and max engine size of 632ci 3100lbs
Big block single turbo bigger than 106mm and max engine size of 632ci 3300lbs
Big block twin turbo max 88mm and max engine size of 550ci 3300lbs
Big block twin turbo maximum 91mm and max engine size of 632ci 3500lbs(deduct 100lbs for 88mm and smaller turbos)
Administrator
Thanks for supporting it Joe!! You guys had 32 cars at the event last year and this was a no brainer for me to have it again this year. I also threw a little extra at the purse to show my thanks!! See ya soon!!
thank you for having us at this years y/b.... are the y/b rules the same as cecils olbt month program they used to have ?
YES, Look at the top page. All the same.
Joe. Looking at the previous yrs results it looks like your camaro cooks right along. :smt077
I use to run a k11 BBF on alky, had a lot of fun with it and broke lots of parts FordSux:
What is your combo.
"PRES."(Jus Sayin CREW)
Do you need a NHRA licence.......???
1 - 8 of 8 Posts
