1 - 3 of 3 Posts
Outlaw 10.5 $5000.00 to win based on 32 cars. $250.00 to enter which gets 5 weekend passes. 18 cars already committed.
Outlaw Drag radial $5000.00 to based on 32 cars. $250.00 to enter which gets 5 weekend passes.15 already committed
SUPER CHEVY @ GATEWAY
OUTLAW DRAG RADIAL VS TRUE 10.5
Weights: At initial tech inspection, inspector will review your combination and calculate your minimum weight. The Tech Inspector will place the minimum weight on your tech card. This weight will be placed on your right side passenger window and sealed. It is the driver/owner’s responsibility to verify the correct combination is on the window for the scale operator, and must sign the tech card to verify the combination and calculated weight minimum.
a. 4 and 6 cylinder and Rotary combinations – no minimum.
b. 4 and 6 cylinder and Rotary combinations – no minimum.
c. Small Block Naturally-no minimum
d. Big Block Naturally -no minimum
e. Small Block Nitrous Assisted 2500 lbs.
f. Big Block Nitrous Assisted – conventional head 2800 lbs.
g. Big Block Nitrous Assisted – non-conventional head 3000 lbs.
h. Small Block Turbocharged 3000 lbs.
i. Small Block Twin Superchargers/Turbos 3100 lbs.
j. Small Block Supercharged 3000 lbs.
k. Big Block Supercharged 3200 lbs.
l. Big Block Single Turbo 3200 lbs.
m. Big Block Twin Superchargers/Turbos 3250 lbs.
* NO WHEELIE BARS
* STOCK SUSPENSION -100 LBS
* UP TO A 315 DRAG RADIAL OR 29.5 X 10.5 SLICK (NO W’S)
* CAR & DRIVER MUST PASS NHRA TECH
* MUST BE A OEM BODY ( NO AFTER MARKET)
Any questions please feel free to give me a call @ 314-403-3755
Thanks Mark Woodruff
We are using rules from the Indy Rage that. It was a set of rules that most in the local area where already using. (midwest). Come on up and play.
Thanks Woody
1 - 3 of 3 Posts
