Looks like they might axe this class if they don't get more participation. If anyone is interested in running this class I would suggest you go to www.raceosca.com and help them out. Looks like there is about a week before the new rules and classes are announced.
They are looking for input to make this class work so if you have a car that could fit the rules and are interested in racing in Canada then go to the site and offer some information or help. Here is the 2005 rules that are currently posted. I believe the class times ranged in the mid nine second zone.
Shawn Morrell
2005 OSCA Rules and regulations
STREET ELIMINATOR
Naturally aspirated class. No power adders permitted.
Body and chassis:
-Lexan/plexiglass window replacements permitted but must appear stock. No visible bracing, screws, rivets, etc. permitted.
-Functioning lights required.
-Full interior required (i.e. must have upholstered door panels, dash, carpet, 2 front seats)
-Sponsor lettering restricted to vehicle glass only.
-Light weight body panels allowed
-Stock style suspension required front and rear. Bolt in replacement components and traction devices allowed.
-Ladder bars permitted with 50# weight adder (must retain stock rear frame, mini tubs OK)
-Stock fire wall and location required.
-No forward facing hood scoops unless OEM equipped.
-Any aftermarket or fabricated ram-air unit is allowed, but it must not be visible from the exterior.
-No rear wing or front spoiler unless OEM equipped.
-No wheelie bars
-No dry sump oiling systems
Exhaust:
-Mufflers required. Must be commercially available units, no home built mufflers. No gutting of mufflers permitted. No inserts style mufflers
-Must exit beyond leading edge of driver’s seat.
No max pipe diameter
Induction:
-Cast aluminum non tunnel ram intakes only. No carbon fiber/sheet metal intakes. Fuel injected entries may use
fabricated sheet metal upper intake with cast aluminum lower intake.
-Single carb or throttle body only with 2" maximum spacer.
-Dominator carbs permitted with 50# weight adder
Small block cylinder heads:
-Non OEM canted valve heads add 100# (i.e. Chevrolet SB2/Ford Yates)
Big Block cylinder heads:*
-Big block entries restricted to the following cylinder heads:
Big Block Ford
-Ford Factory OEM Iron & OEM Aluminum (2 bbl. & 4 bbl.)
-Ford 429/460 Aftermarket Cobra Jet Cylinder Heads
-Blue Thunder 460
-Edelbrock Performer RPM 460
-Edelbrock Performer RPM 460 CJ
Chevrolet Big Block
-Chevrolet Factory OEM Iron & OEM Aluminum
-Brodix BB-1, BB-1 OEF1, BB-2, BB-2X, BB-2 Extra, BB-2 Plus, BB-3
-Edelbrock Victor Jr. Oval Port
-Edelbrock Victor Jr. Rect Port
-Edelbrock Performer 454-O
-Edelbrock Performer 454-R
-Dart Pro 1, 320, 360
-Canfield Big Block Chevy 24.5-800, 24.5-900
-GMPP Signature Series BB Heads #12363400,12363390
Chrysler Big Block
-Chrysler Factory OEM Iron & OEM Aluminum (non Hemi style).
-Brodix B1-BS (Not B1)
-Edelbrock Performer RPM 440
-Indy 440-1, SR
Oldsmobile
-Olds Factory OEM Iron & OEM Aluminum
-Edelbrock Performer RPM Big Block
Pontiac
-Pontiac Factory OEM Iron & OEM Aluminum
-Wenzler Series II (Not Super Chief)
Buick
-Buick Factory OEM Iron & OEM Aluminum
-TA Performance Stage 1,2,3,4
*Please note that some cylinder heads not found on list may be subject to exemption. Prior written consent must be
granted by the OSCA and heads may be subject to weight penalty.
Tires:
-Maximum rear tire size 12.5" x 30" DOT. Any size drag radial permitted.
-30x10.5" slick (non W) permitted
-All tire sizes are as designated on sidewall
Transmission
-OEM style automatic trans
-No clutch less transmissions
-No forward facing hood scoops.
-No wheelie bars
Base weight:
-2900# minimum base weight+3# per ci above 300ci
-Maximum 510ci
Weight adders:
-See small block cylinder heads
-50# weight adder for manual transmission
Weight breaks:
-50# weight break for H-pattern manual shifter
-50# weight break for DOT tire
-50# OEM auto trans with no lock up
-50# weight break for drag radials
-100# weight break for stock angle heads (i.e. chevrolet 23 degree, ford 20 degree)
Fuel:
-Gasoline only
If you are building a race car and you are unclear about rules concerning your class, please contact us.
The OSCA reserves the right to impose penalties for rule infractions and on items which do not represent the intent of the class entered.
Rules subject to change witout notice. If in doubt as to rule interpretation please contact us for final ruling.
Shawn Morrell
STREET ELIMINATOR
Body and chassis:
-No wheelie bars
Exhaust:
Induction:
Big Block Ford
-Blue Thunder 460
Chevrolet Big Block
Chrysler Big Block
-Indy 440-1, SR
Oldsmobile
Pontiac
Buick
Tires:
Transmission
-No wheelie bars
Base weight:
-Maximum 510ci
Weight adders:
Weight breaks:
Fuel:
-Gasoline only
