Ok, I've been experermenting with this and already ran in to a problem.I have been using some cheap no-name wastegates just to try things out, and while its fine with higher spring rates, with a 6psi spring (that seems to be cracking pressure, properly 'open' is far higher) the thing doesnt go fully back in to its seat once the vac is off.Not exactly sure what its rubbing against to stop this, a quick push with my finger and its back in place, but it does.Can someone confirm that with a quality wastegate this will not be an issue? And what brand? Tial?
