1 - 13 of 13 Posts
I have a few ideas for building ramps for my trailer but would like some ideas.
I want a 6 ft ramp, but the kicker is i want it to be light so i can lift them and slide them under the trailer easily. I dont really want to spend the money on alum for ramps so how do you suggest building them and keeping them light ?
cant have yer cake n eat it too, son
i have a set that i use to get my golfcart into the back of my truck, bought the **** depot ramp ends and used 2x8 pressure treated, they aint to bad to lift
if your trailer is a beavertail, you dont have to lift em to high
The lightest cheapest easiest ramps you can get are a 2X12 board. I wouldn't use them but if you want cheap and light, there you go. Back in the 60s and 70s most folks used them. Put some sand in the paint so when wet you don't slip off.
Discussion Starter · #7 ·
I build this pretty cheap
Got any better pics ? what material did you build them out of ?
BTW guys im not trying to be a super cheap ass, I menat that using 1/4 2inch alum angle would be alot since i would quite alot.
Just dont to build some super heavy ass thing from steel angle if its more than what i need
Sorry i tried making this damn pics bigger but no luck..
6 pieces of 2" 1/4x 14" flat bar for the ends a middle
18 pieces 1/2 x 14" angle for the middle supports
4pieces 5 foot c channel for the sides hope this helps
and 2" x2" 16" angle for the ends that hook to the trailer
I use a masory scaffolding plank 2 1/2 x 10 same planks for 10 years. Lumber mill in ont. 22.00 to 25.00 for 16 foot plank. They get lighter after they dry
1 - 13 of 13 Posts
