1 - 20 of 41 Posts
385 ci sbc stroker
Gm 010 block
scat 4340 crank 3.75" stroke
ARP main stud kit (with tray standoffs)
scat I beam rods 6"
ARP 2000 rod bolts
4.040" bore
SRP dome race pistons Hellfire rings
superduty piston pin upgrade
King race bearings
melling high volume oil pump
comp cam 249-12-908-9 soild roller cam
lift: .630''/.630''
duration: 300/308
comp cam t bar solid roller lifters
comp cam chromoly push rods
crane roller rockers (1.5) and std griddles
edelbrock e street aluminum heads
resurfaced 64cc chambers 2.05 intake 1.60 exhaust valves
comp cams 945-16 soild roller valve springs
mls cometic head gaskets
ARP head studs
mildon 7qt oil pan and pickup pan stud kit windage tray
edelbrock vic jr intake manifold
sniper efi or 750
12.9 - 1 compression
hopefully didnt forget anything, Thanks!
Roughed into Pipemax. It all depends on how everything works together.
384.570 Cubic Inches @ 7200 RPM with 100.00 % Volumetric Efficiency PerCent
Required Intake Flow between 255.3 CFM and 269.8 CFM at 28 Inches
Required Exhaust Flow between 175.0 CFM and 197.4 CFM at 28 Inches
600 RPM/Sec Dyno Test Lowest Low Average Best
Peak HorsePower 554.4 577.2 588.6 600.0
Peak Torque Lbs-Ft 448.2 466.7 475.9 485.1
HorsePower per CID 1.442 1.501 1.530 1.560
Torque per Cubic Inch 1.166 1.213 1.237 1.261
BMEP in psi 175.8 183.0 186.6 190.2
Carb CFM at 1.5 in Hg. 801 891 936 982
Target EGT= 1264 degrees F at end of 4 second 600 RPM/Sec Dyno accel. test
Octane (R+M)/2 Method = 107.1 to 110.0 Octane required range
Air Standard Efficiency = 64.59206 % for 12.900:1 Compression Ratio
Peak HorsePower calculated from Cylinder Head Flow CFM only
600 RPM/Sec Dyno Test Lowest Average Best Potential
Head Flow Peak HP = 486.2 569.9 653.6
Thanks stick, what sort of intake might you suggest? Thanks
Bbf, thanks for running that through your program, good stuff.
Looked like a pretty good build list until we got to the Edelbrock E-Street heads....you could have done a lot better there for the same price point. They'll be the cork once the intake isn't.
Holley Strip Dominator intake, #300-25 or better yet the Keith Dorton version #300-110
Probably the Professional Products Hurricane second choice, Super Vic third.
You're not going to get to 500 Hp with just a 185cc head.
Interesting you brought up the 300-25 Eric. I was going to suggest a worked over Super Vic first as I've had better luck with it than a Strip Dominator but with those E-Street's it would probably be a better match.
I would guess about 475 - 500 would be the max with that build
Granted I don't know much about those Edelbrock heads but I must be seriously over estimating them. My buddy built a low compression 9:1 383 with a set of old RHS iron heads and a much smaller cam and made 485 which I thought was a turd.
sounds like either lose some cam and compression and make a street motor or put some heads on it for a race motor...what are you using it for?
Discussion Starter #11 (Edited)
This engine is available locally from a fellow racer. $3800 freshened, intake to pan. Considering using it in a light footbrake chevyII. Th400 with 8" converter and 5.13's for 1\8th mile fun. Nothing serious, budget deal. Thanks for everyones input.
sounds like it work for what you want to do and have plenty left in it with better heads/intake
dump the heads, keep the intake if you must, buy a set of the cheap, shocker, cnc ported 225cc pro-max heads, buy them bare and build with a good set of Ferrea valves and PAC springs, You will have about $1600 in them when done, port match the vic jr and get a 2" spacer. You will have 600hp.
Discussion Starter #14
Dang crackers! More to consider, thanks for that recipe. I'll go look those up.
I don’t know, but we did 3, 355’s with world products Sportsman 2 heads, no porting allowed, that did 560, to 592 at 8,800. I just don’t know how they compare to those edelbrock heads.
Discussion Starter #17
Randy tell me more about those 355 builds, circle track? Thats whats between the fenders right now. 355 with sportsman iron heads.
I would think 500hp would be easy with this package. I made 500hp and 460lbft with unported, 3 angle valve job, 2.05int valve phase 2 bowtie heads 30 years ago. 355ci, 12-1 comp, .650 lift flat tappet cam, unported victor jr and a stock 650 carb/1" open spacer (all by rules). These heads were right around 170cc, and flowed less than the e-street.....?
Sorry. Wasn’t ignoring you. Just now seen it. It was for Wissota A Mod. My first try was with a stock block, stock crank, JE pistons, Carrillo rods, and a set of Sportsman 2 heads. Heads were not allowed to be ported at all. Edlebrock intake that was worked by Ron’s, Comp Cam made to peak at 8,500. Stud mounted rockers, pulled I think 562. We never ran the cheater heads, but we did get to 238 cfm flow with a 2.05 valve. Next 2 builds, again, stock blocks, gas ports, titanium valves, lite trick Callies crank, a cam change, and made 586 and 592. Angle milled the heads as much as possible. Some of the guys running the cheater heads were over 600 hp.
Discussion Starter #20
So i bought the long block in post #1.
Pretty stoked. Finally a decent engine. Going in an older tube chassis chevy II. 2500lbs me in it. T400. 8" tc. 5.13s. 1\8 mile duty.
Thinking some different heads like mentioned above? I will have some iron sportsmans available, heavier with more runner cc. More suggestions appreciated. Cheers!
1 - 20 of 41 Posts
