I have read all the threads for i/c and motor cooling. I still am a little confused i have removed my radaitor and water pump, tapping motor plate for 12am. I am changing my 10 gallon aluminam fuel tank into my water tank. have a very large waterpuppy builge pump, pumps like a garden hose very hd. i want to run ice tank to inner cooler , its mounted in back seat of mustang 2000. then can i y the return 1 to tank and 1 to motor with shut off valve to motor or will water flow path of least resistance back to tank. Whet are some of you guys doing to bypass return inner cooler water to motor. I have read all the search threads just a little confusing.
thanks walter
thanks walter
