1 - 11 of 11 Posts
All I know is that the engine was making noise from the top end and this is what he found when he pulled the pushrods out. You will see the one pushrod with the worn area towards one end. You can actually feel a lip there as well. He said the damaged end was on the lifter side of the pushrod.
My bad. Its a stock cube LS1 with a basic heads/cam package. Don't think it has aftermarket lifters, but if it does they are standard hydraulic.
out of work hair dresser
If that's the case, the lifter collapsed.
anything prtruding into the area? whatever did that was pretty damned hard and had a sharp edge to it.
i have seen them all pollish the end but its where it goes threw the head and it does not make a lip just shines it up from deflection .thatsa new one to me. id lean to the collapsed lifter also.
Definately a dead lifter - Saw the identical thing happen in a 5.3 truck.
Discussion Starter · #10 ·
Well he said he pulled the heads and there was a piece of metal sitting in the lifter tray that was apparently rubbing the pushrod...
I have a set of those 7.350" Comp pushrods with low miles that I was going to post for sale @ $75. Let me know if you need them.
1 - 11 of 11 Posts
