1 - 4 of 4 Posts
i got a stout 23 degree nos engine..I am thinking about going turbo ..the biggest reason is drivability on the street..
engine
408 3.75 stroke 4.165 bore
oliver billet rods
billet crank
bowtie block
pro topline high port heads 345 cfm
how much power can i make with these parts..heres a pic of the engine now
Administrator
Some of these prices are high and you can shop around for better deals with no problems.. I had some deals cut but did not want to list the pricing so I went with list prices in most cases...
$2200 = 106mm turbo
$2400 = intercooler
$900 = 60mm wastegate
$720 = injectors
$250 = throttle body
$50 = TPS sensor
$90 = MAP sensor
$15 = Oil drain
Total for turbo parts = $6625
$1550 = 304 SS tubing, aluminum tubing, V-clamps and Misc..
$300 = 304 SS header flanges
$600 = 2 merge collectors
$200 = Crossover pipe
Total for header and intercooler parts = $2650
Total to have this stuff done by a shop will run between $8000 - $16000
Pistons = $500
Cam = $400
FAST Unit = $3300
Fuel Pump = $850
Water cell = $150
Waterpump = $300
Convertor = $1100
Boost controller = $200
CO2 bottle and misc = $400
Total for motor mods = $7200
Grand total for you to convert will be (doing header.cooler work yourself)... $16475
Having header/cooler work done for you = $21825 (low end)
Having header/cooler work done for you = $29825 (high end)
Do the work yourself and you will need..
Tig welder = $1800
Tig misc = $400
Grinder/sander = $200
Bandsaw = $600
Total for tools needed = $3000
Total for all tools and doing work yourself is $19475
wow thanx for all the info.....that helped a bunch on making a decision.... :D
wow i think its better off fo me to drop the comp to 10.5 in my engine now and put a smaller roller in it..and still have the nos on tap cabable of 500-600hp increase with my 2 systems....
i really want to do a turbo but i would have to refinance my house lol
That's a pretty good break-down, but I think we could knock about $2,500 off of that. You could go to blow-through until you can afford the EFI swap.
- Brian
1 - 4 of 4 Posts
