I have been reading the back threads on this site for around a straight week now, and the knowledge here is rediculous. Now if you would, please give me what tune you would reccomend for a safe 275 setup on my car. Thanks alot in advance. I am in the process of ordering steves flow tool. Just a little case of phone tag going on.
Specs include
455 pontiac 65 over
h beams
eagle cast crank
filled block
good bolts thruout
Kre High port heads
cam is 260ish 670ish on a 108
Victor 4150 intake with an adaptor and a 1050 dominator
a1000 to a aero carb reg to a 12-803 holley reg to the nitrous
4150 big shot plate and noids
I run 31 degrees of timing on motor
th350
chance pro mod 10.5 inch converter
32-14 tire
ladder bar
4.10 gear
msd pro billet
msd digi 6
hvc coil
ngk-5671-10
Please let me know if you need anything else. I have always ran the nos supplied jetting with good luck. But i have never sprayed more than 225. I am stepping up a little and would like all the help i can get.
Thanks fellas
Oh and steve i will try to call you again monday.....Justin
Specs include
455 pontiac 65 over
h beams
eagle cast crank
filled block
good bolts thruout
Kre High port heads
th350
32-14 tire
ladder bar
4.10 gear
msd pro billet
msd digi 6
hvc coil
ngk-5671-10
Thanks fellas
