I would read the instructions from dart on the Iron Eagle block. Since you have an external oil pump I would Highly Suggest feeding the motor from the back of the block. Dart refers to this as priority main oiling. I had some issues with a 427sbf that I put together with an external oil pump and the change I made was feeding it from the front to the back. If you look at the block you will see that in the front the oil passages go in a few different directions, but in the back it goes straight down to the mains. I would also suggest putting return lines on the back of the cylinder heads as well. This will help in keeping the pan from running dry and it doesn't cost much to do. Just some AN fittings and hose. I know it may also cost some horse power , but I would also suggest adding some additional holes in the lifter valley as well.
Just my two cents.
Anthony
