Bringing this back up because I noticed a change when priming a new pump recently.
So, I have had this 427 since 1980 and it's been thru a few different phases, street, mild drag, and what it is now. It started out with the GM Corvett pan with the long gear L88 pump for the street, then it got moved to the Camaro for bracket racing in the high 6's. Then a rebuild going to a Moroso 21047 drag pan with a Meling pump. At this last rebuild we found the pickup had broken the weld at the pump and my machinist said it was time for an upgrade. Never any oiling problems (bearings, cams (hyd, solid, roller) or oil pressure (data logged))
The new pump is a Moroso Billet Aluminum spur gear oil pump # 22164 standard volume/pressure with the same 21047 pan. So, I am getting ready to get the car back out this year putting fluids back in etc. I put the 7 quarts of Brad Penn 10w-40, WIX 51061R filter and grab my ARP primer and a 1/2-inch Dewalt batter drill to prime it up since it's been sitting awhile since the rebuild.
I pull the trigger on the drill expecting it to kick back like it had done in the past, it doses but not very bad compared to all the other times in the past. Hmmmm WTF. I do it some more and not much kick back at all. I got my son to watch the in-car oil pressure gauge and he says 80. I varied the RPMs and correspondingly the pressure rose and fell while getting oil to the rockers.
So, I got to thinking about this thread and was wondering if anyone else has had this experience? I am really surprised that this new Moroso pump takes a lot less effort to spin over.
