1 - 5 of 5 Posts
Has anyone ever heard of the everwear gear on a bullet cam. Saw something on here a couple days ago about one that was for sale and said you did not need to use a bronze gear with that. Ii was going to call John tomorrow and ask about my bullet cam but thought I askk here as well.
Also, High Volume pump or High Pressure, street/strip small block chevy solid roller?? Generally speaking.
James
I think Comp Cams has what you are talking about....some kind of composite dist gear.I would go with a high pressure pump,but not high volume.
Good luck,Grant
With the higher pressure or volume pumps your going to put more load on the gear........You don't need 100lbs of oil press.
James
We have bought roller cams from Bullet with the everwear gears and the Melling select 10552 is a 10% more volume pump which we do use alot and since this pump came out we have not used any of the 25% more volume pumps.
The reason I ask is that I have been told by multiple people to use a High Pressure and Not HV, but my old egine had an HV and I had no issues. It was a melling from before the casting change. I am going to try the melling select high pressure this time as recommended by the machine shop/builder I used for the rotator.
So CNC BLOCKS, do you use just a standard steel gear on the distributor with those bullet cams?? That is what Iw as told by someone and I new to solid roller and don't want to screw it up.
James
1 - 5 of 5 Posts
