Does anybody know if you could cut down a distributor to work AS a plug when using theJESEL FRONT DRIVE DISTRIBUTOR KIT?looking for plug if anybody has one. pt# 8513 msd...
thanksSure why not, As long as you can support the top of the shaft and keep it from leaking. Another cheap way out is to go find a late LT-1 and use the oil pump drive from it. you will have make a boss to bolt it to in the block then put a freeze plug in the intake.
