1 - 18 of 18 Posts
Getting all the parts together to swap 6.0 in my 71 camaro. Any help on what oil pan clears the best would be great! Thanks.
Ice Cream Wolfpack
Those truck pans hang low......Might try an fbody pan if it'll clear on your car, they tuck up tight. Also the Hummer pans don't sit as low as the truck pans do, but they are still a good bit lower than an fbody pan.
I have one of the gm muscle car pans on it now but it is really deep and my car sits super low so i know i cant use that one.I know the f body pans are nice but not sure if it will clear the crossmember. Thanks for the help!
x10 on the holley pan!! fits great!!:cool:
I used a stock F-body pan in a `67 camaro fit good, nice ground clearance too.
Street & performance has a modified F-body pan gives u extra room for a rack & pinion, I used it in a `69 Camaro, pick up didnt fit great but ok.
ls1 s/s notch on 28s
Ls1tech in the hybrid section has all the info u want..i have a 07 an up truck pan for my.mustang..will swap to moroso once i get the cash up
1 - 18 of 18 Posts
