When I shut down the car going through the lights I get a good bit of oil on the plugs. Does this necessarily mean there is a problem? This is running a single fogger.
There is just a little oil on the plugs if I drive the car back. Also, I am running an external wet sump with a new moroso enhanced version vacuun pump drawing 16" of vacuum. C & A rings.
Thanks,
Kevin
Thanks,
Kevin
