Mercury Thunder Bolt That Comes On The 900SC Is The Best Marine Ignition Out There Expensive But Worth It,,I Believe Its Still Available In There Parts Book
I've replaced more Merc Thunderbolt ignitions off those 900 S/C's than I want to think about. If you want to stay with the mercury setup, the only box that works and LASTS, are the ones that came on the early Merc 1000's. I replaced the factory 900 S/C boxes with the early merc 1000 ign boxes and NEVER had a problem yet, and it's been going on 3 years, and on several different boats.
I've been running the MSD 6M-2 boxes with the soft touch rev control on my engines going on my 10th season, installed them in 01. Same boxes, no problems. Now watch, now that I say I hav'nt had a problem, when I go to start the engines in the spring, a box will take a shit on me. LMFAO
I like that idea of having the 3rd box in the event that one goes bad. I've got plenty of friends that have these boxes go bad almost once a season. Maybe it's because mine are so old ??? Did they make them any better back then ??? I'm almost afraid to switch them with all the problems that I've been hearing and seeing out on the water. My engines are only 580cu. in. hyd roller, & 950 hp @ 5900.
