1 - 9 of 9 Posts
On my down pipe should the O2 short radius of the pipe or the long side ? Does it matter?
To avoid a second thread: I have only about 6" after my turbo with a turn out. I have the o2 sensor on the outside radius. I'm not sure I am always getting accurate readings. I moved it to the collector for a pass, and my readings seemed maybe a little more evened out without the possible air mixing. What are the drawbacks to putting it in the collector? Are there limitations to this at some level of boost?
Put it in the exhaust housing.
Needs to be pressure compensated if in the header on a turbo deal.
It depends on the sensor make and model, and the controller.
1 - 9 of 9 Posts
