So I know the rule of thumb is to put a O2 Sensor higher than 9 & 3 o'clock and I have, but I'm about to get my down pipe ceramic coated and my sensor is currently after the first vband and so if I decide to run the car with out mufflers I will lose my weld in bung, so I wanted to weld one into the dump pipe but problem is the only place I can fit it is on a downward section of pipe ( back of turbo has a 90deg bend and shoots straight down) and to complicate things the waste gate dumps back just before the vband where I would drop the rest of the exhaust.
1. Should I read O2 after where the waste gate plumbs back to the exhaust or does thing not effect readings? (I assume not since most dump waste gates to atmosphere)
2. Can I place the sensor in a downward part of the pipe, trying as best as I can to keep condensation trickling over it from gravity.
Car runs e85 if that makes a diff
