If this is a race only piece with open collectors, I would recommend in a primary tube (12-15" from the head). With open collector you get back pulses of clear air which gives false lean readings. Also some collectors leak where the primaries slip in.
At this point do both and you are covered. Put one in each collector and one in #1 and #8 12-15 inches from the cylinder head.
