Nitrous Express - Era of the Diesel
282 inches of oil burning, nitrous huffing monster.
We started with a 282’ Davey Uyehara Chassis.
Here is a current picture. Waiting on a transplant from an upgraded "Duramax GT" motor. Quick rundown on the motor.
DuraMax 7.0 liter
GM-Block
Bullet Cams- 4.00” stroke crank
Crower billet steel Rods
Mahle custom pistons 4.125 bore
Total Seal Rings
MaxSpool Camshaft
GM-lifters, pushrods, and rocker arms
ZZ Custom Fabrication heads, custom porting, beryllium copper seats
REV-valves, springs and titanium retainers
ZZ Custom Fabrication- Flow bench work
ZZ Custom Fabrication-Sheet metal intake manifold
MWR-Custom oil pan
Curtis Halvorson-Billet oil pump
Custom Valve covers by S&T Steel
GM-Gaskets
Industrial Injection-turbo, injectors and fuel pump
KPE-machine work and engine assembly
KPE-Dyno testing 1200 WHP
Possible one of the coolest and most important changes made to the driveline is thanks to Hughes Performance.
This is an XP5 powerglide. Here is a basic overview:
1.69 low gear
1.125 input shaft
Turbo 400 output shaft
Lock-up torque converter
We also add a .78 overdrive gear vendors behind this.
Here, you can see the spacer we had to add to make room for our LOCK-UP 310 mm bolt together converter, w/ serviceable clutch packs. Stall is about 4500 rpms with a 5 clutch disk lock up.
Very trick piece. We have very high hopes for this and we are very confident it will deliver.
We have a lot of very good people on board with this project. The plan as of right now is too be racing in march. I will continue to add as many updates and pictures to this thread as I can.
DuraMax 7.0 liter
GM-Block
Total Seal Rings
MaxSpool Camshaft
MWR-Custom oil pan
GM-Gaskets
1.69 low gear
1.125 input shaft
