1 - 16 of 16 Posts
Dropped of the block, crank,piston,rods,balancer,flex plate today,
Bore , hone, align hone, zero deck, cam bearings, freeze plugs, balance rotating assembly. I'm trying to get it done for Cruising for a Cure at the end of Sept. Still have a lot to go, posi,gears,bearings etc for a complete rebuild ( UPS to deliver today ) that I bought from Brydon who is a member here.
Transmission goes out for a rebuild this weekend back to stock.
Ordered Long Branch exhaust manifolds
A lot to do on a short time.
Tranny back to stock, car is going for a cruise and you're wasting all that money on machine work?
Align hone and zero deck? That screws up the timing chain, weakens the deck, but I guess you get to use those blue perma-torques in the rebuild kit....
Yep. That's correct.
Banned
You may want to reconsider beefing up the trans since you're going to be upgrading to Long Brach exhaust manifolds.
Understandable, but for reasons I have, I will go stock TH400 as built when car was new.
44 days and expecting to have it finished. You must have a good shop. The shop I use is one of the best at machine work. But it takes them 44 days and 15 phone calls just to get started on it.
But my $1200 block work job doesn't compare to another guys $50k pullin tractor engine.
Discussion Starter #7
Can only hope they get it done in the 3 weeks they said. I know it's going to be tuff to do it all in that time frame but almost all the reality shows do it in 10 days, lol
Premium Member
Discussion Starter #16
Dear Mr. 1Slowmopar, I have taken into consideration your suggestion and years of great advise given to all the YB members thru out the years. I have decided to to use the upgraded rebuild kit but keep the shifting stock style ( no hard shifts). Thank you again and looking forward to more expert advise, your pal Lou
1 - 16 of 16 Posts
