1 - 1 of 1 Posts
the setup is a SBF with the old novi1000 single belt system. would like to convert this over to the 2 belt setup, and I am having trouble finding any 100% answers regarding the swap.
Will a Vortech crank pulley work with the 1000 or only the 1200/1500? I see the 1200 & 1500 use the vortech blower pullies, but almost no info regarding the lowers. just from what I can piece together from misc forums over the years, I "should" be able to run the vortech underdrive w/8" 10 rib and a novi 2000 10 rib 3.5 pulley. this would leave me only needing a 10 rib tensioner.
can anyone confirm or deny these parts will work or get me close?
this is what I have found so far.....
http://www.superchargersonline.com/...nfo&cPath=510_1071_1226_1589&products_id=5169
http://www.superchargersonline.com/...Path=510_1071_1073_1243_1249&products_id=6549
if these parts will in fact work, what would you recommend for a tensioner(pt#)?
Thanks for any help!:p
1 - 1 of 1 Posts
