1 - 20 of 20 Posts
Die grinder with 3 or 4" cut off wheel. 1/2 to large tube barely needs a notch, but 1/2 to 1/2 needs the whole notch cut. Be sure to blow the dust from cutting out of the tube if you use any type of grinding wheel before you weld.
It depends on what size tube you are going to join the 1/2" to.If this is a helmet bar or something thats going to hit 1 5/8" tube, I just use a 1 1/2" sanding tube on a air die grinder, you don't have to go too deep to get a good fit.
endmill if it,s a 1/2" cope to fit a 1/2" tube , one could find a 1/2" rattail file and file the cope as well
I've got a small fixture for the 1/2" and 5/8" I made for my Bridgeport and use a roughing endmill.
I just use a sand roll or a half round file to fit it to larger tubing. I use a rat tail file for going to the same size. Not sure what you're doing but I've not had to do this but a couple times Thankfully....LOL
Discussion Starter · #12 ·
Thanks for all the replys guys. And yea, I'm not setup with a bridgeport or anything like that, so the endmill isn't an option. I guess I was looking for some ingenious way of doing this other than with the grinder.
Belt sander always works well, and you can rough it with a pair of shears, just nip a little V out so it wears the belt a little bit less.
If you're not sure how to notch with a belt sander, Youtube it. Hard to go wrong once you get the hang of it, even with a full shop with 2 bridgeports and 2 Mittler Bros tubing notchers, I still notch anything small or anything thin walled on a belt sander.
I have to get out more. My belt sander has about a 3" roller that the belt rides on; on each end. I've never seen one with a 1/2 roller on the end so you could do a cope to fit 1/2 tube to 1/2. With my body shop back ground, body guys use the cutoff wheel all the time. After awhile you get very proficient with it. Looks like I have to find better shears also.
7.86 @ 8800DA 3365lb 275s
mine has about a 3" roller on one end and about a 4 or 5" roller on the other. when your doing small stuff like that you just have the tube at more of an angle. it works well i do a bunch of 1" and 1 1/4" on mine all the time and those are going to 1" and 1 1/4". you don't have to do the notch straight on to the belt.
That makes sense. What about 1/2 to fit 1/2 tube on the belt sander?
Endmill!!! If he had one I'm sure he wouldn't be asking this! ..I use a hand grinder and notch the tube in about 4 seconds
he asked how everyone does the procedure did he not ?? i use a endmill or a large rattail file if you choose to use a grinder more power to you
1 - 20 of 20 Posts
