1 - 6 of 6 Posts
hey guys wiring question , my nitrous setup is a wot switch and right now na i leave off a two step with the brake. is there a way to wire these all together and make it work? thanks
im sure some people may dissagree with it but you can use arc's nitrous time delay relay part number 116-1402 from jegs. and you can adjust it from .1 to 1 sec , in .1 increments from after releasing the transbrake button. hope this helps
1 - 6 of 6 Posts
