using a double cross single plate.can you use it as a 2 stage plate????i was thinking single stage front to back,and second stage side to side...i am using 120 n20 solenoids ANY THOUGHTS APPRECIATED
Yes you can.. Basically need a pair of solenoids and lines to feed each set of bars.. SJusing a double cross single plate.can you use it as a 2 stage plate????i was thinking single stage front to back,and second stage side to side...i am using 120 n20 solenoids ANY THOUGHTS APPRECIATED
Sure can...You can split them too just don't go too much differenceusing a double cross single plate.can you use it as a 2 stage plate????i was thinking single stage front to back,and second stage side to side...i am using 120 n20 solenoids ANY THOUGHTS APPRECIATED
