1 - 4 of 4 Posts
i got the nos brand progressive controller i just put on. trying to get this thing to leave off big kit on these small 10.5 tires. any tips on how this fuel offset knob works??? doesnt say anything about it, only thing it says is it helps if there is a stumble at start.
IMPORTANT TUNING TIP:​
Some high output wet manifold systems can encounter a stumble upon system initialization if a very low initial
power setting is chosen and/or a low batter voltage situation is encountered. In these circumstances, setting the Fuel Solenoid Offset to
something other than zero (always move in small increments, no more than 5% at a time) should move this stumble.
well i tried inbetween 4 and 6 and had a very little bog of start. but the track is also very tight here and it pulled the engine rpm down off the start.
1 - 4 of 4 Posts
