Not sure what to do here. lower a arm and upper a arm are connected by the spindle. Spring is on lower a arm and the top of the spring is in a spring pocket welded to the frame. upper a arm is resting on the stop. When i measure from spindle to fender then jack the car up under center of front frame, has no droop the measurment does not change because of uppers being on stops. I need some suggestions on how the heck to get some travel. Longer springs wont help. Any suggestions would be appreciated. Also front is so stiff i cant even push it down.
