Lost second gear in turbo 350 so pulled apart to check over and found no problem with clutches and seals ,Did air check and everything fine .No that it is back togeather still no second gear .When i change from 1 to 2 it stays in first like shifter is out of ajustment checked shifter like ten times and is all good ,When i shift to 3 takes 3rd fine.The shift kit is transgo stage 3 full manual. Any help please would be good
thanks 350lj
thanks 350lj
