1 - 8 of 8 Posts
i did my burnout same as always stage car left on brake felt lazy shifted into second to find it hit limiter because it was in second it has reverse no first gear and 2 seconds and drive and trans brake still works but its in second.
If you have no 1st gear you probably broke the roller clutch .Not very common.Are you sure you dont have manual 2 and manual 3 and not just 2 in manual2 and manual3?
no shifter is adj perfect all gears work fine just no first gear when its in first on trans its in second but the brake still works i know very weird.
If the low roller is broke you will never get first because the reaction carrier isnt held but with the brake on the rear band will ground the reaction carrier to the case and allow the gearset to make ratio and wedge with brake applied
I tip my hat to you trans guys - I look inside one and I might as well be working on the Space Shuttle!
Discussion Starter #8
thanks guys for input ill post results after we tear it apart.
1 - 8 of 8 Posts
