1 - 16 of 16 Posts
Its going to drop down to 4 degrees and my bottles are in a unheated garage. Is it safe to leave them in there or should I bring them in the house? Just a little leary from when I overtightened the safety blow down adapter last year and the disc popped. Just want to make sure the cold won't effect it and I'm going to lose 10lbs of the good stuff.
I freeze mine to fill them and they sit in my trailer outside all winter. Never had any issues.
If your storage area was getting to over 100 deg then you might have a problem but a far as being cold you won`t have a problem. In Liberty Dan
-40? fuck that! its going to be -2 here tonite i cant imagine another 40 degrees to the wrong side of zero!
Discussion Starter #8
-40 holy shit! I don't know what I would do if it was that cold! The heats gotta be running non stop in the house.
EFI/N2O JUNKIE
Shyt, then we're in the middle of a heat-wave compared to you. Still double-digits, was 11* just a little while ago. Tired of this cold-shyt!
At -40°F the bottle pressure is 136 PSI, so your system will still work if you correct the jetting for the lower pressure. ;) At 90°F the pressure is 960. Calculating the jet area requires compensation for the density change, which is from 40 lbm/ft3 at 90° to 67 lbm/ft3 at -40°. At 10°F the pressure is 326 PSI and density is 60 lbm/ft3.
Trevor Stripling
I would recommend putting caps on the bottles. The lower temperatures will cause the valve parts to shrink and can sometimes lead to leaks. Also, some cheap guages will leak when they get too cold. Worse case you will end up with an empyt bottle.
Trevor
Good point. We all know about how the cold caused shrinkage and hardening of the O-rings in the booster rockets and caused the Challenger disaster. The sealing material in bottle valves is subject to the same physical behavior.
Proud Canadian
Yes the furnace has being running non stop lately.I put the bottles in my shop for now until this cold snap passes.My truck has square tires it's so cold..
Almost reminds me of my time when I lived in Alaska. Summers were great but winters SUCKED THE BIG ONE! Just glad to be at home in Colorado! Now I just need to get my car finished so I can play! My bottles are all empty right now, and will be getting them tested before they are filled again, so I could care less about the temp in the garage right now except for when I'm working in it!
"Darkness"
Thanks for the usefull info. ;)
1 - 16 of 16 Posts
