Thanx guys, I have used the speedtech difuser plate before and liked it but I have been told to try the Zex perimeter plate, I'll need more opinions before I buy the setup because once I buy it Im kinda stuck with it. This will be going on a small block ford so the only concern is starving the front and rear cylinders,the difuser seemed to solve that problem so Im curious if the Zex plate will also.
